Bad positioning or too fussy? | on ElectriciansForums
Discuss Bad positioning or too fussy? in the UK Electrical Forum area at ElectriciansForums.net
sehs527
England
I'm a homeowner and looking for some advice. We have taken on a house renovation and had an electrician do a rewire. The second fix has just been done with socket faces now on etc. We've spent a little extra on faceplates but I'm not happy with the positioning with some of the sockets/switches. Thankfully most are ok but there are a few grouped together that are all spaced differently and it looks messy (pictured on studded walls): The fan switches are different heights (one I can reach the other I can't), they're different distances away from the door way/architrave.
I asked the electrician about it and understandably it's hard to be accurate during the first fix and I guess stud wall frames can affect positioning. Just wondering what you guys think?
  • [ElectriciansForums.net] Bad positioning or too fussy?
It looks like he made a poor job of estimating where the centre of that narrow piece of wall would be after it was plastered and the door trim in place. Sort of thing that comes with experience.
Fan switches are for maintenance only, and are exactly where I would have placed them. Both look the same height to me.
We are all good at blowing our own trumpet and with many years of experience can throw a critical eye at most insallations
We could also know very well what a good and aesthetically pleasing installation should entail
Throwing my critical eye ate the installation I have come to 2 conclusions
Number 1 is unless you take care to get accessories sited well the installation can look a little amateurish
No 2 is unless you see various installation standard its difficult for that person to know good from bad, that includes electricians as well as others
If I were to site boxes for a switch on a stud wall, I generally use 5 inches from the start of the frame for my distance,( estimate the door lining width when no frame is fitted)
Any socket below would start at exact same distance be it a single or double
I have a habit (good or bad) of looking at items for level spacing and symmetry
In my own installations I make sure that trait is strictly followed and items are level spaced uniformly and symmetrical
Having stated the above, the photos are not anything unique to the the electrical industry
If there's a stud in the way, in a place where the correct positioning is important, such as the narrow wall in question, I either make sure the chippy doesn't put it there in the first place, or cut in a couple of trimmers, above and below, and remove the offending piece of stud.
He may have also not anticipated the style of architrave, and if there have been another inch of plaster between socket and frame it would instantly look better. I've seen a heck of a lot worse and from the surface you can't see what the other trades did to scupper the job!
Why not simply say that it's bothering you and can he can move the socket over a bit? Worst case, swapping to a single would look better if there's something in the way.
Interested to know how you do that if the wall is already boarded and skimmed
I think the answer to the op is yes!
If you specified where they were to be ie sockets halfway between door and corner, light switches 8" from doorframe etc then it is bad positioning.
If it was a more generic as in to the right of the door frame, etc, then you can't really complain, and it is a bit fussy.
In saying that, it looks like they just put the back boxes alongside wherever the joists were (wouldn't be surprised if they were just screwed into the joist at the side/top/ or bottom) which I would consider somewhat lazy and rough.
Personally, I (and I suspect most on here) would try to be consistent, and try to place fittings in aesthetically pleasing positions.
Anyone else use these.
Nah, they don’t look that great to be fair.
I normally use my laser level, then mark up and ask the client if they’re happy with the positions before I start chopping out.
Yes I use a draper one that does both single and twin it's not as big as the one you linked to, and it is very handy especially if used with a laser. Good in big kitchens ect, then just fly round with the multi cutter! Template even has the center marked.
Perfect size for dry line boxes and metal KO boxes.
like this. Didn't pay that much for it though!
Sy
Sy
I have that one as well, but find having a vertical level is sometimes handy
They do save a bit of time, especially when used in conjunction with a laser level.
But each to their own 😜
Surely running a pencil around a box is just as quick, especially when used in conjunction with a laser level?
One box with torpedo level.
Multiple boxes with laser level.
Genuinely curious what the benefit actual benefit there is?
I found torpedo type levels, especially the red laser type, are pretty useless on a long wall, self levelling green are a different kettle of fish.
The draper one has a height set, so you can be sure that all heights from the worktop will be the same.
When doing a single isolator switch next to a double socket for instance, you know the gap between them will be the same, much quicker and accurate to mark.
Also, you don't have to carry a level, and a pair of back boxs just the tool and a pencil.
Well it's fairly apparent how they work, but I questioned what real benefit they provide. If you're fitting a single box, it's unlikely you'll bother setting up a laser - yes this template has an integrated level, but who doesn't have a small level to hand in their toolbox/bag?
If you're marking out multiple boxes, and setting up a laser line, I don't see the benefit over a box positioned along that line.
Spacing between boxes is no great hardship and the usual methods of measuring allow spacing to be set at any distance of your pleasing, rather than a single, pre-determined distance.
Would you often find yourself marking out a kitchen with only this template and a pencil to hand? I suspect it's more than likely you'll have at least a small level and tape measure to hand at that stage in a job.
Maybe I'm missing something here as my main concern when marking out boxes is ensuring they're exactly where a drawing indicates they should be.
All I can say is you carry on doing it your way like I did for years without using one, i, ll join the 1000s of people who bought one.
That's fair enough, but I asked what the benefits were and you pointed out that it saves you having tools in your bag that will already be in your bag for numerous other reasons.
I don't see any reason why you shouldn't use these templates, but don't see any real benefit in doing so.
Reply to Bad positioning or too fussy? in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
Quinetic switches are your friend here!
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
5K
Thanks for everyone's advice. The electrian came to look today and said all the wiring was sound but switch plate was sticking a bit. He's...
