Installing New Wall Light Switch with 2 Black and 1 Red Wire? | on ElectriciansForums
Discuss Installing New Wall Light Switch with 2 Black and 1 Red Wire? in the UK Electrical Forum area at ElectriciansForums.net
damgyeah
USA
Trying to install new switch to turn on a ceiling light.
There are 2 black, 1 red, and ground (bare copper) wire.
How do I wire this to a single pole switch? Or do I need double/3-way switch?
The switch should be the only one to on/off the ceiling light.
[ElectriciansForums.net] Installing New Wall Light Switch with 2 Black and 1 Red Wire?
Reply to Installing New Wall Light Switch with 2 Black and 1 Red Wire? in the UK Electrical Forum area at ElectriciansForums.net
Ah yes my apologies, thank you much appreciated.
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
You actually need to use the light switch since that’s where the lights are controlled from. The red wires should be your travelers going to...
Yes still see the odd red white and blue out in the wild, usually without cpc, iirc that colour code was only used for a short time...could be...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
