R
RogerJ
My first post after extensive Googling. I'm qualified as an elctronics engineer (retired) Posting this question here in hopes that an enquiring electrcian will know the answer. The last time I changed a tank stat, I disasembled the old one and kept the 18" brass tube and central steel thin rod.. ( I do things like that a lot) I can see how it works but wonder if anyone here knows if that central thin rod is plain steel or Invar..
I have a use for a thin Invar rod in a DIY clock.. Thanks..
