candymancangt
I have a question for you all, We recently moved, and the old house had the analog meter on it, the new place has 3 structures on the property.. a barn, a defunct kennel which im going to turn into a workshop and the house itself.
All 3 buildings have these smart meters on them.. Our first electric bill was... well insaine.. 300$.. never in my life have i had an electric bill this high, and it claims we used 900kw of power in the house alone. Not possible.. not when we had the wood stove running nearly 10 days of the month, about 10 more days temps have been in the 50-70s.. and the other few days we did use the heatpump and gas furnace. On the 25th christmas.. it was 74f out.. my mom and I were out cutting down trees to free up the 14 acres of land we have.. The windows were open.. no lights were on, everything was off.. but SOMEHOW we used 6kw of power at 11:30 am.. at 11:30 am we were outside.. So explain to me how we used 6,000 watts of power in one hour with the heat off, and the windows open at 74f outside temps
The house is single level with a crawl space in one section and basement in another, the furnace propane is new 2016, the heatpump is 30 years old nearly, but it was looked over by a professional company the r22 charge was good, the system worked, the coil needed slight cleaning but other than that it works.
Anyway, i cannot grasp how much power is being used in this house with nothing running besides the fridge/freezer which is older but set high so it doesnt run alot. We just moved.. so we have nothing in the house and the lights i changed to LED right away.. The Kennel for example. Had a motion sensor flood light that was broken, it would flicker on and off, staying on for 10 min, then turning off, and flicker on again for 10 min.. turn off and repeat.. It had a LED Flood from GE i put in it, that draws 14W....
How in the heck, is the daily electric bill for that barn at .13kw per hour ? Thats 130 watts per hour.. It should be under 100, hell under 50w. But it keeps reading 130watts. Whats even more interesting, is i finally removed that flood, and installed a 50W High pressure sodium dusk to dawn light. Its on 12 hours a day.. I can see when it comes on and off, and guess what.. The usage hourly says 130 watts. aka .13kw.. When the light turns off, it drops to 0kw, then in the evening it goes back to .13kw.. There is no way a 50w HPS is running at 130 watts, even with an ineffeciant ballast.. lol, There is also no way a 14w LED flood is running at 130w as well
Seems suspicious to you ??? Sure does to me..
The barn is the same thing, but NOT as bad.. I have two mercury vapor lamps 175.. dusk to dawn running on a 30ft pole that gets power from the barn. I also see when they come on an off, as power from the barn goes from 0 kw to .50kw.. You mean to tell me two 175w lamps, are using 500 watts per hour ? That would mean each lamp is using 250w. Thats just not possible. even if they were horribly in efficient ballasts..
The house though is the same.. I have 320w of high pressure sodium lights running for just 4-5 hours.. When i turn them on and off, i can see the jump and drop in power usage.. The hours they are running the house meter says power usage is on average about 0.9 to 1.10 KW.. The house during the day uses around .13........... ooooohhh get it ? another .13 kw usage when nothing is on.. Anyway, .13 minus 1.0kw is 87kw.. How are 320w of light magically using 870 watts ?
Why are all the meters reading .13kw for the lowest readings. If i turn on a 5w light bulb... the reading shows .13kw Im basically being told im using 3x more for energy than im actually using.. Im very very mad, and ive called the power company about this, but all they try to do is get a "energy" saving guy to call me and tell me what to turn on and off, and how to use my power.. Listen im not stupid.. i see the pattern here.. I can have a 14w led running and it says im using 130w of power.. then i put a 50w high pressure sodium fixture in and it says im using 130w.. I can turn on a 5.5w LED and itll say im using 130w..
The smart meter is NOT smart.. i dont think it can read power usage properly like a analog meter can. Especially when it comes to energy efficient light bulbs like LEDs
