Soft starter problem | on ElectriciansForums
Discuss Soft starter problem in the UK Electrical Forum area at ElectriciansForums.net
Tangerang selatan
I want to add indicator lamp for ON,STOP, and trip , which terminal should i connect? And what about terminal no 1 and 2? Please help
  • [ElectriciansForums.net] Soft starter problem
Reply to Soft starter problem in the UK Electrical Forum area at ElectriciansForums.net
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3
4K
It's unlikely tht a small domestic garden pump and a single lamp will come anywhere near close to overloading even the smallest (3A) fused spur...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
The wiring looks ok. When you say it trips the breaker, do you mean the MCB supplying the starter? if so what is the rating of the MCB
I am back to try and hook up my Frankenstein compressor. 60 gal tank, Ebay 5hp motor, HF 5 HP, 145 PSI V-Style Single Stage Cast Iron Air...
