C2 or C3 ? Wrong brand of mcb | on ElectriciansForums
Discuss C2 or C3 ? Wrong brand of mcb in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
newfutile
Nearly Esteemed
Supporter
hemel hempstead
Which code would you give to a Wylex board populated with Hagar mcbs ,Wylex main switch and Wylex rcd.
Wylex once told me that nsb and nh breakers are not allowed on the same busbar !
  • [ElectriciansForums.net] C2 or C3 ? Wrong brand of mcb
As above, agrees with the BPG #4
Code C3 - Improvement recommended
Mixed branded switchgear components within a consumer unit or distribution board where:
  • there are no signs of thermal damage to component or associated connections
  • the enclosure/assembly hasnโ€™t been modified to allow installation of the component
  • the component is securely fitted and all connections are adequate
  • correct manual operation of the component
  • direction of use of toggles/switches is the same as existing devices
Note: If any of the above criteria is not met, this would warrant a code C2 classification to be recorded.
Actually I would like to know why it ended up like that. After all, Wylex MCBs are not exactly hard to come by and Hager are, while good products, not exactly the cheapest choice either.
Very odd!
Maybe it had NSB Wylex once, i work for a housing association so its hard to figure out what the contractors thought ,the case was quite badly butchered and cracked so I have installed a new consumer unit today !
So what's the consensus on Wylex 3036 boards fitted with plug in MCBs? MCBs are 'down' for off; older 3036 boards are 'up' for off on the main switch.
Interesting point, though I guess all such plug-in MCBs operate the same way though!
EDIT: That is also a UK versus EU+USA sort of thing. Our convention for most switches has been down=on but I often see up=on abroad.
Also I guess in that specific case it is not "mixed brand" or against the manufacturer's recommendation as Wylex make them specifically for their own 3036 boards!
The cover and/or any danger of fingers accessing live parts is another issue of course.. I have cut out the inside of the lid before so it fits round a set of MCBs OK.
Still, even allowing for the cover (or lack of) my own feeling is they are a safety upgrade for such boards as few folk in the general public are competent to change fuse wire (getting both rating and terminations correct) and the risk of plugging the fuse in to a live board, and possibly on to a fault, to me is far higher than the risk of someone idly pulling one out to poke the terminals. Also I think those MCBs are all 3kA breaking, so higher than many of the 3036 fuse/carriers deliver.
Obviously not nearly as good as a new CU with RCD, etc, but better than leaving some old codger to try and fit 5A wire in the dark.
Reply to C2 or C3 ? Wrong brand of mcb in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
4K
  • What is the refundable option on ๐”ผxpedia? Cancellation Policy
    What is the cancellation policy for ๐”ผxpedia? ๐”ผ๐•ฉ๐•ก๐•–๐••๐•š๐•’ ๐• ๐•—๐•—๐•–๐•ฃ๐•ค ๐•’ ๐•˜๐•–๐•Ÿ๐•–๐•ฃ๐•’๐• ๐Ÿค๐Ÿฆ-๐•™๐• ๐•ฆ๐•ฃ ๐•”๐•’๐•Ÿ๐•”๐•–๐•๐•๐•’๐•ฅ๐•š๐• ๐•Ÿ...
  • 24/7~ASK#QuEstion>Why are flights so cheap in Turkey?+1-{804}-853-9001
    Why are flights so cheap in Turkey? Flights to Turkey can be cheap for several reasons...
  • [Speak๐Ÿ—ฃ๏ธ AA]โ„ขHow do I speak to American customer service?24&7!!Fast!!Service
    ๐“ฃ๐“ธ ๐“ฝ๐“ช๐“ต๐“ด ๐“ฝ๐“ธ ๐“ช ๐“๐“ถ๐“ฎ๐“ป๐“ฒ๐“ฌ๐“ช๐“ท ๐“๐“ฒ๐“ป๐“ต๐“ฒ๐“ท๐“ฎ๐“ผ ๐“ต๐“ฒ๐“ฟ๐“ฎ ๐—ฟ๐—ฒ๐—ฝ๐—ฟ๐—ฒ๐˜€๐—ฒ๐—ป๐˜๐—ฎ๐˜๐—ถ๐˜ƒ๐—ฒ ๐“ฒ๐“ท ๐“ช ๐“บ๐“พ๐“ฒ๐“ฌ๐“ด ๐“ฝ๐“ฒ๐“ถ๐“ฎ, ๐”‚๐“ธ๐“พ ๐“ฌ๐“ช๐“ท ๐“ฒ๐“ท๐“ฒ๐“ฝ๐“ฒ๐“ช๐“ฝ๐“ฎ ๐“ช ๐“ป๐“ฎ๐“บ๐“พ๐“ฎ๐“ผ๐“ฝ...
