I am constantly confused by the online installation form and what they refer to as "main switch", and "installation worked on". If I have the following arrangement, on a TT system:
Which is the "main switch / switch fuse /breaker / RCD" referred to in part 8? 100mA RCD, 45A Switch fuse, or the Consumer unit Main switch?
Then which device is "supply to DB is from" when it is not connected to the origin? 45A switch fuse with the 100mA RCD as "associated RCD"
Or should I add the 45A Switch-fuse and SWA as a seperate circuit or DB, as otherwise there is nowhere to record the test results?
Many thanks in advance!
Bob.
Bob.
