Double socket problems!! | on ElectriciansForums
Discuss Double socket problems!! in the UK Electrical Forum area at ElectriciansForums.net
rennie158
Uk
I’m changing my double socket and upon removing the old one, I seem to have 3 separate wires coming in to it. So essentially I have 3 live wires, 3 neutral wires, and 3 earth wires. How do I connect the earth wires to the new socket as it only has 2 terminals? I’m fitting new chrome black sockets so want to be careful!!
[ElectriciansForums.net] Double socket problems!!
  • [ElectriciansForums.net] Double socket problems!!
Looks like you have the original ring (reds and blacks) then someone spurred off the ring in new cable (brown and blue)
Reds/Brown
Black/Blue
Green Yellows
That wiring (the red and black bit) is over 50 years old. Might be time to think about replacing the bits of the installation not on show, rather than just the decorative bits.
A rewire seems extreme. No reason why that black and red won't pass IR tests.
Not as such, but the number of points fitted in the '60s falls well short of what most people require today, and I'd almost guarantee that further inspection would unearth some very dubious modifications and additions.
Why limit that to the 60's? Could easily apply to late 80's and early 90's and well beyond. With modern builds it seems spec is low to hit for extra's left right and centre. Was on one today, 4 bed done around 2012, master bedroom and the big bedrooms 2 double sockets per room, small bedroom had 1. At least it was double sockets mind.
@westward10 may appreciate this...SHOCKING
Parker Morris report in 1961 set the minimum number of sockets, etc in a dwelling. Not sure if it's been superseded.
My childhood home had two singles in each bedroom, opposite diagonal corners. Nothing on landing. Single in hallway downstairs.. I think only 4 singles in living room, even behind the telly and I really can’t remember the original kitchen.
Kept Woolies going in selling 4 way adaptors in those days.
Luxury! I currently have 2 singles in each bedroom, a single in the hall, and 2 doubles and a single in the living/dining room.
There are some old heater outlets i could repurpose, but adding new sockets would be a tedious and messy affair as all the internal walls are brick. My PC setup has a a 6-way trailing socket, 2 4-ways and a 5-way, with only a couple spare, all hanging off a single wall socket...I really need to sort this.
Reply to Double socket problems!! in the UK Electrical Forum area at ElectriciansForums.net
As you said in #9 get an electrician involved. The information you are giving is not clear as you do not understand what is being asked which...
As with many of the DIY questions we get on here.... We dont mind helping out (at least most of us... lol) but i would advise to know your own...
