Hi guys and girls,
I recently failed part of my AM2 assessment on the cat5 data part of all things! Any help would be much appreciated.
Problem is I don’t know where I went wrong. Here’s a quick run down.
Cable installed in top or bottom of dado with the plastic bridge fitted where it crossed over the middle section with the 230v stuff in. I think the bridge could only go one way and I kept the 230v behind it and the cat5 on the front side of it.
I was provided a wiring diagram for connection which was different to the colours indicated on the back of the cat5 socket but as the specification said to follow all wiring diagrams I went with that option. Fitted what I believe is a dust cover over terminations once punched down and there was a hole in the dust cover I presume for the cable entry? Didn’t fit very well though as the cat5 is very thin. I also couldn’t see any type of strain relief on the back of the socket where a cable tie would go?
All tested ok on my testing part with the cat5 tester but came back as a fail for that section on the data installation?
Any help would be much appreciated as I don’t want to repeat the same mistakes on my resit!
Thank you in advance for any pointers.
