Hello. I'm fitting some Fibaro Dimmer 2 smart switches and hoping to get some advice on best practice around cable colors. Usually the modules are installed behind the switch in which case it's obvious what is connected to perm live, switched live etc. However the need has come to install the module in the crawl space above the room. I'm going to fish down some 3 core and earth, one for the common (Sx) and one for each momentary switch (S1, S2), see diagram below.
My question is what colors should I mark each core as, since they arn't being used for a standard purpose?
Thanks in advance.
Thanks in advance.
