Are Danson consumer units and RCBO's ok? | on ElectriciansForums
Discuss Are Danson consumer units and RCBO's ok? in the Electrical Tools and Products area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I am in the habit of fitting 'Fusebox' consumer units. However, I notice that Danson are even cheaper.
Has anyone fitted them? Are they acceptable quality? Any problems with the RCBO's?
If they are 'Chint' like quality then I would rather avoid them. Chint are the only RCD's I have ever come across that are faulty.
Cheers 😃
I haven't yet heard of them and they may well be fine. But I'll probably stick with Fusebox as they seem very good quality for the money and I haven't had any problems at all. As we all know you get what you pay for. 🙂
For the pennies difference in price , I will stick to FuseBox
Probably best. 😊
Thanks for replying both.
Cheers 😃
Obvoiusly you have not found the Proteus ones.
Heres a pic of one that died when we pressed the test button during and EICR.
[ElectriciansForums.net] Are Danson consumer units and RCBO's ok?
I hope that failed due to an overload somewhere and not a design or manufacturing flaw…
I knew there was a reason I used the insulated handle of a screwdriver to press an RCD test button…..
Reply to Are Danson consumer units and RCBO's ok? in the Electrical Tools and Products area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
This was posted this week, on topic ....... https://niceic.com/newsletter/omission-of-overload-protection/?dm_i=7G1W,7GCE,K4L2A,WHET,1
