Best screwdriver for roofing bolts? | Page 2 | on ElectriciansForums
Discuss Best screwdriver for roofing bolts? in the Electrical Tools and Products area at ElectriciansForums.net
When using heavy duty galv cable tray and all them roofers to wind down to flatten that lip (8 on each join), I always found a good pair of mole grips on the thread of the bolt an a spanner on the nut and bob's your uncle as they say and you can even snap the spare threads off with the mole grips a quick file and a dab of glav paint all done.
No mate, to the best of my knowledge NO such tool has yet been invented. In actual fact, the last time that a tool was invented, purely for our trade, probably was THE bush key.
Armeg do a purpose made end to fit in roofers can fit in impact driver or hex screwdriver
  • [ElectriciansForums.net] Best screwdriver for roofing bolts?
I have the armeg as a lot of old stuff I come across has them as earth bolts, and yeah for what it is its expensive but it's been great for old rusted bolts in switchgear with a bit of impact driving and made life a bit easier!
I hate gutter bolts in anything (except gutters where they can be ground off) give me a normal bolt, torx, hex anything other than a slot heat or gutter bolt!!
More than pays for itself within a few lengths of tray or trunking.
They are a next level pain in the ---, I have a couple of big old yellow handled Stanley's that I've been using for about 15 years now!
A very clever and talented old engineer made me a driver for them using two halves of a penny washer tig welded to an old pozi 1/4" drive bit that I had for ages until I dropped it down a fixed downpipe I was gutted. He sadly passed away not long after I met him but that guy could make anything from nothing!
I think we are all agreed that roofing bolts are one of the worst things to come across and to top it all they usually have square nuts on them, two questions what do roofers use to put them on with, why are they still available.
Yes I don't know the answer to any of those questions tbh, they are good from the fact that the heads are low profile and relatively smooth for tray strut ect! Square nuts I've never really had issue with 😁
Roofers probably use a hammer,
oh no sorry nail gun😁😁
I posted this a couple of years ago, my solution to the roofing bolt, I just took a grinder to a 25mm flat wood bit with a hex shaft, it clips into the Wera handle and works fine, also doubles up as a small scraper/ prybar
I never use roofing bolts in my job now, never liked them anyway, but I still carry it as it's been so useful
millwall ken ... yeah i'm definitely not an apprentice! unlike MOST members of the forum I'm not so egotistic to be afraid to ask questions on the forum as well as answer them! I thought that maybe someone had come across such a toll where as a screwdriver has two flat blades at 180 degrees from the other.
After all sometimes even if we have been doing things the same way for years, there may be a better way out there that someone else is pracising, Thats what the forum is all about aint it?!
There seems to be a hell of a lot of the 'regulars' on here who seem to be able to answer every post but never seem to post any questions!
Wish I was so knowledgeable!!!
Look at ARMEG. They do a dedicated screwdriver bit for M6 roofing bolts in two lengths. They are impact rated as well.
Reply to Best screwdriver for roofing bolts? in the Electrical Tools and Products area at ElectriciansForums.net
Best screwdriver for old style flat head roofers is, of course, someone else’s. 😉
I always have a double syringe of 5 minutes apoxy kicking about for stuff like that. You can usually get it from the pound shop rather than paying...
You can buy the wera ends in singles for replacing broken and worn ends which is nice
Not really its clear in black and white. Not knowing the regs isnt the regs books fault.
I also have a few no name cheapy tool bags probably similar to your Aldi/Lidl variety that are set up as a 'grab bag' with the exact tools and...
Trending Electricians Tools
New job, new tester; Megger 1741+, those that have one; anything good/bad to report? Work also trusting me with a Flir E5 magical heat-reading...
95K
Absolutely correct they hold water, shrouds are totally unnecessary. 20s is 24mm spanner, 20 large is 30mm spanner.
45K
If that little thing, plugs your butt, you better eat slowly. 🤣
2 3 4 5 6 7 8 9 10 11 12 13 14
41K
B
I'd say everyone has knowledge gaps in their area of electrical work I know i have quite a few i work on to fill them in
2 3 4
29K
I too have been tempted.. I’m buying for my son. He’s in his2nd year at collage and looking for apprentiship. Sadly it’s almost impossible in my...
25K
Of course. “Ye canna change the laws of physics” EDIT. oh blimey, I just spotted the date of the OP. ? Thank you very much @Lord lee jan You...
23K
Only way to do it in a tight space
21K
The display on the Mft pro is not very durable mine is broken already 😡
21K
Only lawyers , solicitors and dodgy chat up lines charge for picking up the telephone 🙃
2 3 4
20K
J
I'm not entirely certain as it's very tough, but brittle when cold.
2 3
19K
nicebutdim
N
