Required MCB for Doorbell Transformer | on ElectriciansForums
Discuss Required MCB for Doorbell Transformer in the UK Electrical Forum area at ElectriciansForums.net
Norwich
Hi guys,
I’ve just looked in my consumer unit and I’ve got space for an extra MCB and a rail transformer for my ring doorbell.
I’m planning on adding a matching mcb however I don’t know if I need a 3A, 6A or 10A version.
The transformer is British General Fortress 8-24V AC 8VA Bell Transformer Module
So I’m working on the basis that 8VA / 24v = 0.33a
However should it be 8VA / 240v 0.03a?
Either way I’m assuming a 1a unit will do the job?
Can anyone offer suggestions please?
Personally I'm not a fan of doorbell transformers inside consumer units.
Most aren't installed with any regard for Band1 / Band2 cable separation, or with any regard for easy maintenance later. I think it's safer to have a fused spur and an external unit so anyone can replace it in future.
But the actual answer is a 3A breaker, if available, will be fine. Someone has commented that this model can put out more than 24V and cause notifications of over-voltage on the app btw.
[ElectriciansForums.net] Required MCB for Doorbell Transformer
Reply to Required MCB for Doorbell Transformer in the UK Electrical Forum area at ElectriciansForums.net
