Currently reading:
Nearly electrocuted just after EICR — tester denies any responsibility
Discuss Nearly electrocuted just after EICR — tester denies any responsibility in the UK Electrical Forum area at ElectriciansForums.net
I had the first EICR done on my flat last week, which failed with some C2s for having an older (2001) plastic consumer unit with no RCDs, but otherwise passed:
A couple of days later I'm called to the property due to no hot water and find the electric boiler is dead. There's a connector block in an enclosure under the boiler so I removed the faceplate to have a look and saw continuous blue sparks from a very bad connection, to say the least:
At this stage I'm already feeling aggrieved as this had worked flawlessly for 6 years and suddenly just after the EICR there's this terrible connection that can't have been sparking like that for years, and the control board in the boiler is likely blown (later confirmed).
I'm wondering why there's three neutrals jammed into the same connection and notice one is from a loose cable going down behind the hot water cylinder. Wondering where it goes I reach down to wiggle it and... BANG!
Photo isn't very clear because I've immediately switched the main switch off so it's dark. The cable had bare ends and was just dangling behind the cylinder! It had come into contact with the it as soon as I reached down and thus the bang.
The electrician who did the EICR and the agency I paid deny any responsibility for not finding any of this, saying "checking wiring centers and cables from cylinders is not part of an EICR. Inspection and testing is carried out on the fixed wiring where accessible, as far as the isolator to the heating system, which was carried out."
(The cable isn't from the cylinder and in fact has nothing to do with it.)
Is it really the case that a professional test costing hundreds of pounds isn't even expected to find a live cable with bare ends dangling in an easily-accessible location right next to the consumer unit? Just another box ticking exercise with no real assurance of the safety of the installation at all? Please forgive the rant but this could easily have electrocuted me.
It's absolutely correct and true that not everything will be checked during a periodic inspection and test of an electrical installation. Aside from the cost of doing this, excessive dismantling is liable to introduce faults.
That said, for the likes of a domestic dwelling I would certainly attempt to at least visually inspect externally (without opening) as much of the electrical installation as possible, where visible and accessible. The extent and limitations sections in the report should detail what has been agreed (as well as operational limitations which might exist). I would have flagged numerous issues with that wiring centre without even having removed the cover. That said, I pretty much never issues satisfactory reports - because it's very seldom that you will encounter an installation with no C1, C2 or FI observations.
items 1 & 5 should both be C3.
the missing covers on those boxes for the wiring centre should have been picked up as C2s if nothing else.
and a kick up the arse for the wet-pants that put his pipework directly in front of said boxes.
There is some argument on here as to whether no rcd on sockets is a C2 or a C3 but that’s a different discussion.
They have noted C2’s so the EICR is unsatisfactory. There’s no such thing as “otherwise passed”
There is a box on the report for limitations of testing. Some don’t do wiring centres…. Others may not even open lighting jointboxes… As mentioned above, the act of opening a cover or removing a faceplate to do the tests can actually introduce faults where there wasn’t one before.
A live cable hanging like that is a C1, immediately dangerous situation.
I’m surprised they missed it, but then… a dark cupboard…. Being told not to test wiring centres….
You’ve had this fault for 6 years?
No previous EICR? No work done to the heating within this 6 years?
This is the first EICR ever as the property was squatted for a couple of years through the pandemic. It's hard to believe that cable has been dangling there live for 6 years since the gas boiler was removed but it's possible; as far as I know no work has been done during that time. But it can't be a coincidence that the boiler failed due to that bad connection immediately after the EICR, which does show the dangers of poking around to test things — but I've just been almost electrocuted due to not poking around to test things...
Wiring associated with the Unvented cylinder and any other controls associated with it would be checked on the annual inspection done by a G3 registered heating engineer / plumber.
When was the Unvented cylinder last inspected?
Just checking I have this right - you almost got electrocuted after removing a cover, seeing sparks, and sticking your hand in to give the offending wire a wriggle?
I believe the hanging bare wires were already hanging, and not because the cover was removed.
But I do agree, most of us would isolate and test before poking about…
But your general member of the public would not be expecting bare wires.
You would of thought so but some just about check the gas appliances. and a drop test if your lucky.
That's the Landlords annual gas safety Cert.
Unvented isn't included in that but should be checked annually whether it's part of a gas, oil, electric or Heat pump system.
And it should have a certificate or record of the service / inspection.
A Landlord would have no defence if there was incident involving an Unvented cylinder and could not provide proof of annual checks on it.
This thread is a good example, the wiring is out of the remit of an EICR so whoever did that would have a good defence, unless the cable was hanging down in front of the C.U.
Yep up to the FCU is part of the electrical installation. After that it would be classed as fixed appliance.
Yes, tested up to the fcu, but I honestly can't understand why this was not spotted during the EICR visual inspection.
And the limitation to test only up to an fcu would only apply if expressly agreed with the client and recorded in the limitations box.
The wiring isn't associated with the unvented cylinder, or any controls associated with it. Just happened to be dangling behind it. And there's no gas so it isn't the gas safety's remit either.
Reply to Nearly electrocuted just after EICR — tester denies any responsibility in the UK Electrical Forum area at ElectriciansForums.net
