Upgrading an existing consumer unit with RCBOs | on ElectriciansForums
Discuss Upgrading an existing consumer unit with RCBOs in the UK Electrical Forum area at ElectriciansForums.net
NickTG
london
hi there I have a plastic consumer unit that was installed about 8 years ago - inside is the standard array with RCD. Im planning to switch to RCBOs (and cost wise I actually bought a fully populated consumer unit as it works out a lot cheaper )
my question is to comply and get through a landlord electrical safely check can i just replace the suite of MCBs(+RCD) with RCBOs or do i need to change the entire box for a metal one ?
The box is by CED but im planning on using BG RCBOs
  • [ElectriciansForums.net] Upgrading an existing consumer unit with RCBOs
If as you say you bought a fully populated board this should be metal, why not use that.
thanks everyone for the comments / have decided to use the new metal box - its just a bit smaller than the existing one and its recessed a bit into the wall so requires some plastering around the sides - so was just trying to avoid doing the cosmetic work after the upgrade
Reply to Upgrading an existing consumer unit with RCBOs in the UK Electrical Forum area at ElectriciansForums.net
What is the distance from the point outside the house to the shed?
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
6K
suffolkspark
S
I’ve not got any, just had a quick look on Google there. That might actually work, never realised you could get something to fit, thanks for that
Having a transformer on the loose inside the CU seems bad practice, but putting it in an external DIN box would seem the obvious solution. Better...
... and reading a bit further on in the big brown book, 534.4.7, SPD installation in conjunction with RCDs:
4K
