I have installed and outdoor enclosure to primarily house outdoor network and IoT devices. I need power for PoE injectors, power supplies, etc. The Carlon outdoor enclosure is 12 x 12 x 6 and has a sealed lid attached with screws. I extended the existing outlet (GFCI) by using 1/2 PVC, various fittings and 12ga stranded wire. The outlet installed in the enclosure is outdoor rated. The device screwed to the outlet is an Ethernet surge protector that is grounded/connected to the green ground wire screw inside the box.
p.s. I know the conduit run is a bit wonky - I had to cut a 45 off to get it to mostly level up. Picture looks worse than IRL....
Should I have done this differently? Is there a better way to do it? Thank you in advance for any/all help.
