WillemV
Hi y'all!
I am positively stumped right now. Lemme explain.
I am replacing old outlets at my in-laws. Their house, built in 1970, got flooded during the horrific TX winter spell. Painters sprayed over everything and drywallers seemed to have had mud to spare.
I got all but one bedroom outlet done, but this one scared the bejeezus out of me. I usually check which wire is the incoming hot, before I turn off the breaker. Well, it turned out on this one three out of the four wires are hot. The two black wires and the two white wires were all on the right terminals. The terminal connectors/jumpers were intact.
With the outlet removed, the two black wires and one of the white wires all trigger the tester. I cross checked the voltages and they come up as follows:
Right now, all wires are disconnected and I have the three hot wires capped. That also killed the power in the adjacent bathroom and the hallway lights.
I used a tracker before I opened the outlet and found the 15 Amp breaker it is on (left leg), which is the one that also has that bathroom and hallway on it. However, the tracker also consistently lights up on a 20 Amp breaker on the right leg. That 20 Amp breaker consistently lit up the tracker with several other breakers on the left leg as well. Not sure if this is related.
What could be going on here? Is there anything I can do to fix this?
Any insight is much appreciated!
Cheers!
- Willem
Cheers!
- Willem
