A simple lightning rod vs a commercial | on ElectriciansForums
Discuss A simple lightning rod vs a commercial in the Electrical Engineering Chat area at ElectriciansForums.net
What is the difference from a simple lghtning rod vs the modern ones they sell for 1,000pounds ? Do these really work so much better ?
  • [ElectriciansForums.net] A simple lightning rod vs a commercial
Probably about £950
Not quite sure what you are asking without a bit more info,
Lightning finials come in many different shapes and lengths and materials, the 2 you have shown one looks quite short and the is long and both look to be manufactured using different materials
As UNG, not sure exactly what the question is, but the difference between simple and commercial products is mainly that commercially produced ones are designed, engineered, extensively tested and guarenteed to work.
And in the case of lightning protection to not cause any damage to the building whilst the protection system is being hit by lightning.
Additionally a simple rod or system wouldn't be accepted by a building's insurer, if lightning protection is a condition of insurance.
The first picture is an ESE and the second a regular air terminal. The ESE is expensive but only needs 2 downconductors and earths so normally quite a cost saving.
Reply to A simple lightning rod vs a commercial in the Electrical Engineering Chat area at ElectriciansForums.net
I have this Adee Fusadee lightning arrestor in my electrical cupboard, the area I’m in is prone to thunderstorms from spring to autumn so it is...
Recommended Sponsor News
Hi everyone,
