Merlin Gerin RCBO options? | on ElectriciansForums
Discuss Merlin Gerin RCBO options? in the UK Electrical Forum area at ElectriciansForums.net
pc1966
V.Nearly Esteemed
Dundee
I suspect this has already been covered, but just wanting to check if the Schneider C60H RCBOs are OK for use in a 1990-era MG board:
[ElectriciansForums.net] Merlin Gerin RCBO options?
OK, a quick check shows they have been discontinued, so anyone (probably @westward10 ) know if Schneider has a current RCBO that is compatible with the above board?
Yes, I know a new board might work out cheaper than a few RCBOs but would like to check first as it was a good product in its day.
Not seen them like that they normally have neutral and functional earth fly leads.
Ok seems to be more than one in the range. Still, it is looking like a new board is probably a better bet, more so as the 2nd CU is Memera 21 and probably no sane options for RCD either.
It is a rather odd set up, the MG board on the ground floor feeds the 1st floor via some 16mm T&E from the 63A MCB, but the 1st floor board then feeds some of the ground floor as well (also it feeds the top/attic floor).
I've fairly recently used some acti 9's in the same board as the one you have pictured @pc1966 . They seem to be pretty much an exact match, as if they have been rebranded (this is a guess though).
I have 2 RCBO's spare if you'd like them (No charge) as I hardly ever work on these boards.
The plug on neutral type is not compatible, you need the flylead type. I would also recommend replacing the board, merlin made good stuff but its quite common to find the older boards have plastic parts that are deteriorating and have gone brittle. The iso sliders can far apart when operated, MCB dinrail clips crumble and the clips that hold the busbar assembly to the pan backplate can fail.
That as another nagging feeling. I have also had the odd bit of older stuff fail when trying to fix it due to brittle plastic, and I found a split blanking cover as well suggesting someone broke it trying to do something in the not too distant past.
Reply to Merlin Gerin RCBO options? in the UK Electrical Forum area at ElectriciansForums.net
Has anyone used the Schnider power tags? i have a cunstomer that wants to meter all there A/C units so need to fit metering to a few mcb's/rcbo's...
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
Recommended Sponsor News
Hi everyone,
