I have a partially completed installation of solar PV. The panels and inverters are working fine and generating plenty of power (13kWp), but I am aware of 4 issues :
1) G99 Fast Track was applied for and permission granted to go ahead with the installation; the DNO letter included the following text :
As far as I am aware, no commissioning form etc have been submitted by the installer to the DNO. Certainly Octopus cannot get an MPAN from WPD due to incomplete paperwork.
2) Assuming the above letter means that the system needs to be export-limited (to 3.68kW ?) then presumably a CT clamp is needed. There is none.
3) The MCS certificate is incorrect in terms of the Total Installed and Declared Net capacity figures. There may be other mistakes.
4) I have no schematic of the system; there may be other omissions.
The original installers are not responding to my communications so I have been trying to find another company who would be prepared to complete the work; most either do not bother to respond to my enquiry or say they would not touch it. Is there anybody here who would be prepared to take on the task, or can recommend someone ? Costs (within reason !) should not be an issue as they will be deducted from the outstanding invoice from the original installer.
