Fuse missing from main disconnect panel | on ElectriciansForums
Discuss Fuse missing from main disconnect panel in the UK Electrical Forum area at ElectriciansForums.net
San Jose, CA
Hi there, I run a recording studio out of an early 50's built warehouse. I've been having electrical noise and ground loops in my audio equipment since I've been here (almost a decade) and I've finally decided I can't deal with it anymore. I'm going to install a new main panel as well as new ground rods. While I was preparing to start the job I noticed that the main disconnect for the power coming from the pole is missing a fuse in the middle bay. What could be the reasoning for this? Would this be causing any issues?
There is a second disconnect at the ancient main panel that has all three fuses installed. Any advice would be fantastic!
Thanks!
  • [ElectriciansForums.net] Fuse missing from main disconnect panel
Thanks!
Could you please tell us what voltage it is to ground and phase to phase
Reply to Fuse missing from main disconnect panel in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
Hi all, Great to of found this forum. Much respect for keeping everyone safe! My background is in commercial data and Audio Visual. Been...
By code the first panel after the meter has to have 2 ground rods with # 6 bare wire going from the neutral bar to the first ground rod unbroken...
The sub panel you choose to buy has to be outside approved. Make sure it has enough space for your breakers to feed your branch circuits. All sub...
m new here and want to learn. I have a project I want to tackle but if it is above my means I will call an electrician. I have a main disconnect...
