Discuss How old is this rewireable fuse box? in the UK Electrical Forum area at ElectriciansForums.net
Not highjacking this post but the one I previously took out, the back was made from wood. Does that narrow down the date of the board?Back of frame made of wood?
It’s funny- most things I rip out without mercy - I always carefully keep all the bits of those and out them carefully back together for some reason.
I thinks it’s a sort of subconscious respect!
Thanks for the info
I took one out on Monday that was the original CU when the house was built I reckon that was mid to late fifties installI took out one recently I’m guessing 1960/1970 but that’s just a guess
The dual screws were good workmanship , unlike the rubbish we install todayOne really good point about them is the double screw terminals.
Until the latest models, all the outgoing Live and Neutral terms were double screwed, as well as the incomers.
Good positions for the 2 bars also, IMO.
I don't think that will happen with too many variables with different cable sizes and some with one cable or two or possibly threeWonder when we will get Wago-style spring-clamps on MCB/RCBOs?
See in lots of other countries you are only allowed 1 cable in 1 device , it is against their regs / code to 'double up' in a single device.I don't think that will happen with too many variables with different cable sizes and some with one cable or two or possibly three
For now at least. Though it is not beyond belief they would regulate to 2 cables per breaker (e.g. RFC or two light feeds) and then it would be practical.I don't think that will happen with too many variables with different cable sizes and some with one cable or two or possibly three
ExactlyFor now at least. Though it is not beyond belief they would regulate to 2 cables per breaker (e.g. RFC or two light feeds) and then it would be practical.
But two cables of what CSA it would certainly make the configuration of a 32A MCB / RCBO interestingFor now at least. Though it is not beyond belief they would regulate to 2 cables per breaker (e.g. RFC or two light feeds) and then it would be practical.
Why lose the versatility we have nowI would do one step further and do away with the single screw type busbar and make all breakers rcbos plug in with back stabs so their is no exposed bar anymore
Plug in breakers can just as easily be swapped out / moved around as breakers that screw to a traditional busbarWhy lose the versatility we have now
Not sure, but some spring connection DIN terminals cope with 0.2mm to 10mm which would cover most domestic cases.But two cables of what CSA it would certainly make the configuration of a 32A MCB / RCBO interesting
That's assuming you can get a board of sufficient size in the space vacated by the old boardIn a modern board you don't really need to double up feeds like you had to in the old smaller way boards
Reply to How old is this rewireable fuse box? in the UK Electrical Forum area at ElectriciansForums.net
