Is this a fused neutral cutout? | on ElectriciansForums
Discuss Is this a fused neutral cutout? in the UK Electrical Forum area at ElectriciansForums.net
Shropshire
I’ve not seen one of these before and i have a memory of them needing to be upgraded by the DNO.
Just wondering as well what the BSEN is for it. Is it 1361 or 88-3
[ElectriciansForums.net] Is this a fused neutral cutout?
IMO it's capable of being DP fused but late enough that it is more likely to have a link in the neutral. Note the two recesses for identification discs on the front of the sealing chamber.
Thanks.
I’ll get the DNO to check as the consumer unit is to be replaced and I need to stick an isolator in. So they may as well check it when they pull the fuse.
The bloke that lives next door works for Western Power. But is currently on holiday or I’d have asked him to check it today. 🤪
Reply to Is this a fused neutral cutout? in the UK Electrical Forum area at ElectriciansForums.net
Your electrician shouldn't be doing anything to the cutout, that is the property of the electricity supplier and they make the connections to it...
davesparks
That was my first thought, obviously the electric was free when we took that photo but only whilst I carried out a quick test. There aren't any...
Thanks. I guess i might need to swap the 3036 for a 50A MCB & enclosure as there is currently no way to replace the tails that easily!
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
