Todays lighting puzzle | on ElectriciansForums
Discuss Todays lighting puzzle in the UK Electrical Forum area at ElectriciansForums.net
timhoward
Broke Internet
Supporter
Solutions
Oswestry
Before I take it apart….
Anyone like to take any guesses?
Fitting a new (customer supplied) light fitting. Fitted, Came to a Zs test and oddness prevailed to the degree I wasn’t ready to leave it connected. In the end I bought it home for more testing.
Bulb holders 1 and 2
[ElectriciansForums.net] Todays lighting puzzle
Bulb holder 3
Same readings occurred when at customers house. Any guesses what I’ll find inside?
High R/loose connection on the N for bulb holder 3?
Essentially yes. This was a bit silly - it turned out to be
a) Me not thinking completely straight when very tired (this was the 'quick and easy on the way home job!')
b) daft fitting design
They are ES fittings. It turns out that unless there's a bulb in bulb-holder 2, there is no N continuity to bulb-holder 3.
I happened to pick number 3 for first test, and did a double-take at the readings without remembering that's what it would look like with no N connection at all.
Then I took fitting down, got clear IR tests, and found there was no N connectivity. (All the time without moving test adaptor from position 3)
So I put the pendant back up and said I'd take it away and look at it.
( This design also means that if you have a working bulb in number 3 and are changing number 2, you can touch the side N contact and get full potential. )
If all the lampholders are the same would that mean lampholder 2 is actually faulty and has evaded quality control at the manufacturers
If this is a customer supplied fitting I think I would suggest they returned the fitting for a replacement and then test the new fitting for the same issue
Contacts: (no connection to 3rd one)
Number 2:
I've had it apart. It's arranged as per diagram above.
There is no physical way one could get a wire to the 3rd isolated contact as it's entirely enclosed and I'm pretty sure this is the intended design.
It's an expensive Polish-made fitting which is mechanically well made but totally let down by the 3-way cheap ES bulb-holder. I don't believe it's faulty. I've decided to tell the customer I'm not very impressed with it and will suggest a different fitting is used.
I have a feeling there is some sentimental attachment involved (she is Ukrainian) so it won't be an easy discussion.
I don't consider it any more dangerous than a BC fitting so don't think I should refuse to fit it outright.
Reply to Todays lighting puzzle in the UK Electrical Forum area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
Have you tried tapping the fitting with a glass hammer. I have found these fittings suspended on skyhooks before now and they just dont hang right...
    • Funny
UPDATE, after contacting Paypal, uploading all the emails and evidence the sending the transformer back I have now received a full refund...
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3
4K
