Why wouldn't a volt pen pick up voltage? | Page 2 | on ElectriciansForums
Discuss Why wouldn't a volt pen pick up voltage? in the UK Electrical Forum area at ElectriciansForums.net
manchester
Well I'm confused ! 🤔
Just went to isolate some kind of antique shower pump thingy in a bathroom for a plumber mate but the switch to it in the bathroom was painted over several times so I couldn't get my voltage tester with probes on it. So I used my non touch volt pen on the switch and the cable going into the switch which showed 230v power.
I isolated what I suspected was the power supply in the basement - an old wylex isolator. Tested the bathroom switch again with my volt pen and 0 volts - Fair enough. That would suggest the isolator was the right call.
Thing is though, When I tried my volt pen at the cable at the isolator (as a whole and also each individual conductor in the isolator) I got no voltage displaying on my pen - with the isolator energised or not. I checked the fuse in the isolator which is fine.
I retried my voltage pen on the switch in the bathroom with the isolator energised / not energised, with the same results.
SO, why am getting a reading with my voltage pen from the bathroom switch and cable at the bathroom switch, but not getting a reading at the isolator outgoing cable??
I'm going to have to return when I have more time to smash open the switch and do more substantial tests cos I like this plumber but I'm still at a loss on why this be...
[ElectriciansForums.net] Why wouldn't a volt pen pick up voltage?
Reply to Why wouldn't a volt pen pick up voltage? in the UK Electrical Forum area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
Ah OK, that makes sense. Thank you Avo.
@Megawatt can you help
They should, but no. Also that would mean taking up loads of old floorboards, on an already carpeted room, filled with furniture, etc. My life is...
5K
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
