Dodgy trade pictures for your amusement! - 1 Million Views! | Page 431 | on ElectriciansForums
Darkwood
Or even vertically by the side of the RWP and horizontally under the widow, there may not be enough cable, but nothing a nice neat 45deg angle under the window would not cure and look much neater.
A few pictures from my phone of past jobs
Just for clarity, the 3 brown 16mm singles taped up coming out of the trunking are fed from the crappy distributuion board pictured,supplied from on the top right Triple pole breaker, 63A, three phase 400V 😱, trunking was not earthed, went to another moody three phase board the other side of the warehouse about 40 meters away, pretty much taped up their entire length, must have took most of the day taping them all together, they were joined with 30A connector blocks about 4 times throughout the run
  • [ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views!
Did you get the ‘it works ok 🤷🏼‍♂️’ response when you pointed it out? 😂
I wish I hadn’t taken the cover off now….
New customer. Lighting fault, breaker would reset, 4 or 5 times… then wouldn’t reset at all, and tripped with a crack.
Boiler is also off this lighting circuit so I’ve ran a temp supply for that just now.
Reading 5Mohms and rising on L-E and N-E.
Suspect circuit is second from left and disconnected for now.
Other issues with board include inner cores of flex on left most breaker supplying bell transformer (no bell) into exposed connector block. Took that out straight away.
There’s so much excess copper on show.. and no idea with the black going into a breaker.
Neutrals don’t correspond with lines and this was supposedly rewired in 2002.
I’ll get all the faults sorted, then get some rcbo’s for it.
This might confuse a DIYer...either the label is on upside down, or the cables are reversed on the tray...
It works though, now!
I apologise for the state of the ferrules, they were re-done once I had the unit running.
