Vortigern
What does the DNO equipment look like. For instance does it have any RCCB or even RCD at the supply end. I assume this is a sub-main. How does the supply get to that CU?
Discuss Plastic board above entrance with bs1361 fuses only - no RCD protection. How would you code that? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
So I am guessing there is no ryefield or main plant cupboard that one meter does the flat direct does it? Is that how all the flats are fed each with their own cut-out? Unusual.
Reply to Plastic board above entrance with bs1361 fuses only - no RCD protection. How would you code that? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
