Three phase motor (two speed switch) | on ElectriciansForums
Guest viewing is limited
Discuss Three phase motor (two speed switch) in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am trying to wire a two speed switch to a three phase motor. I have continuity checked the switch in both positions 1 - Low and 2 -High (See attached) Can someone confirm if this is correct and would this change the speed. Secondly i have a cable coming from what is I assume from the delta overload contactor and a a cable coming from the back of the wheel head motor switch (see attached). Where on the switch do these two wires get connected.
  • [ElectriciansForums.net] Three phase motor (two speed switch)
Reply to Three phase motor (two speed switch) in the UK Electrical Forum area at ElectriciansForums.net
I really can't see a problem with it assuming there is a neutral there.
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
Recommended Sponsor News
Hi everyone,
