About Stepper Motors | Page 2 | on ElectriciansForums
Discuss About Stepper Motors in the UK Electrical Forum area at ElectriciansForums.net
_q12x_
New York
Actually there is another forum discussion until reaching this cct here. It was an entire evolution of it.
This cct is working ok but in certain parameters. It is limited to power and heat over the Tr's.
Is working fine in the 5V range for 2 of my stepper motors that I tested with it. But if Im bringing up the voltage, to 10V, I get 140dgrC on one Tr and about 60dgrC on a few others. At 5V, everything stays at a constant 50dgrC which I call it normal and safe.
One of the test motor is a Nema17 17HS4401. The other one is a scrapped stepper. Both work fine at 5V and even at 10V, no one was heating. Over 5V, especially at 10V, only the driver's Tr's were cooked to (almost)death. I stopped the power after smelling hot metal in the air.
I am also receiving a couple of L298N IC's. They are coming in the mail, not arrived yet. But I dont expect much difference from them, compared to what I have here. It would be nice to be better ! I hope so.
- My question:
- How to make this cct more powerful? To drive more power through the coils of the stepper motor? (and not blow up it's Tr's!)
I already have 2 answers to this question in my mind, but I dont want to influence your answer. I expect to be pleasantly surprised. Haha.
[ElectriciansForums.net] About Stepper Motors
Thank you !
Good morning. I may be a few days starting because I am overdue to deliver on a promise to my wife to install an outside light to cover the far end of the garden so that we can see our Jack Russell when she goes out at night. I am accompanying my wife on an outpatient appointment and this weekend we are away. Thus, next week I will begin.
I have in mind using optocouplers like the ones I mentioned earlier to make the transition between the 5V logic waveforms and the high side transistors. MOSFETs and perhaps some changes to your waveform generator. I have found the NEMA motor and will buy one.
I made this movie last night and is completely unrelated to what we are doing here. Im braging with it and show it off. You can actually see on the table this project we are working right now with the H-bridge and the motors, but I push them away to make room for the new one. Is good to watch a technical video while you are away with your troubles. Especially when you are waiting for something and starts to be boring. See how much I care for you?
I am waiting with my wife at addenbrookes hospital Cambridge. The hospital is very large. Not had chance to watch your last video.
https://en.m.wikipedia.org/wiki/Addenbrooke's_Hospital
A question- what do you intend to use the nema17 stepper motor for? Knowing what for would provide me with some (extra) motivation to get started. 😉
You will, when you will be bored out of your ears. Waiting in hospital, I know that story, I actually waited for days at some point in my life. I hope is not something serious, but a routine check, right? I wish you and your wife good luck. Good luck from Romania is a precious thing, you get it very rarely in your life. So use it well.
The motor eh? Haha. Well... not really-really a plan per say... but I do have something in mind. Its a very simple thing, but we will get there. Trust me. For now, I want a very serious and stable and reliable stepper motor driver/controller. That is capable (most importantly) to drive at full potential these motors ! Not like my dinky driver that is able to spin them but not really put them to serious work. You get the idea.
Another important thing is accessibility ! We, humans, in these modern days, we got used to already made boards that are performing very well, no doubt about that. But it should be correct to have the proper circuits to build those well performing boards they sell so expensive as well. Dont you think? I very much do. So from that aspect of things, I am very ----ed off and I want to correct it. I want a (very) good performant cct for driving these motors, available, online, on internet, and not hunt for help. That's important ! In my mind. I hope I transmitted to you the same feeling I have. And you should transmit it as well further.
I doubt my circuit will be the acme of what is possible. To do that requires considerable testing and real life trials to discover and fix problems which may at first be hidden. That is why in my view some of the best technology is often years old. But my breadboard may work reasonably well as a technology demonstrator which with your patience you can perfect.
Stepper and mosfets arrived. And I thought I would do some reading up since the last time I made any circuitry for stepper motors was 40 years ago at college:
https://www.ti.com/lit/ml/slua618a/slua618a.pdf?ts=1666798524312
If you dip into this reference you will see there is more to a good driver circuit than at first blush*. Maybe too mathematical for you but the text is reasonably understandable.
at first blush
phrase of blush
  1. at the first glimpse or impression.
    "his next decision was at first blush disconcerting"
  • [ElectriciansForums.net] About Stepper Motors
WOW- it must cost you a small fortune.
I have a success ! With the mosfets !
I managed to install a primary external PSU of 12V to drive all the gates and the voltage regulator and the logic circuit.
And a secondary PSU, my variable PSU that I can monitor the Amps and Volts on the motor itself.
Here is what I tried:
The 4wire NEMA17 - the new one, worked excellent at the lowest fv to the highest. I didnt reach 5V, but up to it, like 4.5, 4.8V. But the amperage was considerable high, at 1A, 1,2, 1.5. I keep it running most of the time somewhere at 300mA-to-600mA.
Some of the Tr were hot and some were Very-Hot.
I am very happy that nothing burned out.
Well... in my first try I actually forget a link wire in the breadboard and that got extremely hot and the plastic got in thick smoke and I thought it was a Tr. But the Tr was fine. Haha. But that was the only incident and at relatively low power.
No motors , no Tr and no important components were damaged.
The Voltage regulator started to heat up quite high with a heat sink on it. BIGGER is BETTER was always my motto. Haha. But that can wait.
The only failure I have so far, with this current circuit that I just tested, is the second 4wire scrapped motor. It only trembled and never rotated. I switched its connection wires a lot and the motor could NOT start rotating. Only vibrating. I noticed the new NEMA17 was trembling until 4V but after 4V started rotating. So, I increased the Amps and Volts for the scrapped one, I reached 5.5V but at a very high Amp of ~2A, so I dialed down for safety. The Tr's got extremly hot at that point. I did all this experimentation as quickly as I could, in a couple of seconds, no more than 10s per high level of power. Usually I keep everything working at a very safe temperature and power of 300mA and somewhere at 2V. At this level Ican see trembling in the motors and also no heat on the Mosfets or the VoltageRegulator.
Like the BJT version, this mosfet version has the Voltage dependent to the Amps. But is a lot better because is not limited like the BJT was. I couldnt reach 1A with the BJT. If I remember right. At 600mA everything was starting to get extremely hot. So usually if I remember right I was keeping at 300mA or less. Back then the scrapped motor worked perfectly for the tiniest impulses. But now.....????
Now that I have 2 functional circuits, its a stage completed at this point.
I will try to build the BJT that give me the best results, as a stand alone board. As weak as it was, it did served very well for testing the motors. This more powerful mosfet circuit.... hmmm, I will come to it when I will finish the BJT one. If the scrapped motor worked with this mosfet circuit, I would have been very happy. So far im only 50% happy.
comments from the other forum:
I only look at the top Transistors. All the bottom ones are drive at 5V ! So 4 mosfets in the lower side. Hmmm. I didnt notice it. But it worked like that, haha.
Someone noticed 2 of the mosfets are still working at 5V, and I looked more closely and 4 of them , the bottom ones, are at 5V but I notice after all the thing worked as described. Hahaha
It worked fine....
Good morning. I have been studying your latest driver circuit, the one with some mosfets circled in red. I think you have made a wiring error between the cd4017 and the two H bridges. If you think of each of each H bridge as being made up of diagonal pairs of mosfets ie \ and /, then for wave switching the pairs are switched on as in my attachment to #7.
The sequence, looking at my #7 table is 1, 4, 2, 3, 1, 4, 2, 3, 1……..where these numbers refer to the pairs of Q transistors read left to right 1, 2, 3, 4.
Your pairs of diagonal transistor are being switched 1, 3, 2, 4, 1, 3, 2, 4, 1…….
If you study your diagrams at #1 and #36 in the way the 4017 is connected to the two H bridges you should see what I mean.
Thank you for your last comment.
My friend mister @marconi ... check this out, what I received today !
The far right IC that almost has no marking left on it is the one from you. I notice mine are bigger. I didnt realized it when I buy them. Eh...
Cool, yes ?
View attachment 103229View attachment 103231
Cool, yes ?
Your chips At28c64 have 64k of memory whereas the At28c16 I sent you had 16k. Otherwise they have the same technology inside. There are two more pins for the address on yours A11 and A12.
There are two more pins for the address on yours A11 and A12 to address 64k rather than 16k since 2exp2 is 4.
Im not sure how your math works but here is my math:
2^16 = 65536 bit combinations (your chip)
2^64 = 1.8446744e+19 which is 2 quatrilions probably of bit combinations. And not 4 like you calculated. Haha.
16k memory locations is organised as 2048 x 8 bit memory locations shortened to 2k x 8 bits = 16k. 2exp11 = 2048. Address word A0 to A10.
64k is 4 x 2048 x 8 bit = 8192 x 8 bits = 8k x 8 bits. 2exp13 = 8192. Address word A0 to A12.
Aha... I believe this number 2048 and 8192 are referring to the Addresses/or/MemoryRegisters of the IC.
I think I get your point. Im not used to think in these terms, I still lack some experience but im not far away. Thanks for your kind explanation !
- I open it before I buy it. Im always reading the datasheet, I got used to it and is a routine now for me.
Good thought but im doing it all the time. I didnt read it corner to corner, I only fly over it, I smell it. Haha. Probably I will, in the future.
- For now I showed you that your influence grow with me. I liked the IC especially after that HARD circuit I made, also with your help, I realized it is a very good chip to have. And it was quite cheap anyway so I made the step and took them. How I will use them... we'll see in time.
- My question:
View attachment 102851Thank you !
Pondering the circuit at your #1, I am doubtful whether when the CD4017 output is logic 0 that the inputs to the base of the upper transistor and the input to the NOT gate are pulled down to 0V because those 4 diodes, one on top of the other, are reversed biased so no sinking current can flow through them. The diode path can only source current which raises the potential at the base and input to the NOT gate - not lower it. I would insert four 10kR resistors as I have indicated in the attachment to provide a current path to the 0V rail when the input to the diode is logic 0.
-I actually did that in my experiments. Here are my results: In the simulator, I got a very small performance boost in the motor spinning. Almost negligible. In reality, nothing really looked different. With or without those resistors, the motor(s) were driven the same. I put 100k indeed there, in all my experiments. But I put 10k and 1k and the result was the same so I decided to go quite up in the resistor value since the performance and the result was equal in any circumstance.
-Your explanation is very pertinent and I like it. I may try it again and see if indeed something improves.
Well done with figuring how to draw over an image ! I know it is hard to do it for you. But it pays off, doesnt it? Heh. I cna teach you some advanced image editing stuff, since you know me, Im actually a digital artist and not someone who aspire to be one. Anytime, my doors are open to you.
Reply to About Stepper Motors in the UK Electrical Forum area at ElectriciansForums.net
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
I assumed this will be easy, or at least intuitive. This project is not intuitive at all. Pity. I imagined I will solve the problems along the...
That sounds to be more of a control issue rather that a motor issue Are all the limit switches working properly and not sticking occassionally
Nailed it! Thank you for your help
I would call an electrician.
