Additional gang meter socket | on ElectriciansForums
Discuss Additional gang meter socket in the UK Electrical Forum area at ElectriciansForums.net
USA
Can I add a 2 gang meter socket on the other side of the building and to know If the supply line use as distribution for new gang?
  • [ElectriciansForums.net] Additional gang meter socket
Reply to Additional gang meter socket in the UK Electrical Forum area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
Thanks for the replies, I appreciate it.
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
