Hi all, DIYer here.
I am moving a light switch and adding spots to my lounge.
In order to move the switch I firstly identified the constant Live going into my exiting switch, spliced this with Wago’s onto a new cable and down into my new switch. Using the 2 plate method I then ran a switch cable to my first spot from the new switch, connected the two neutrals at the switch with Wago’s, the constant live to COM and my switched live to L1. Flicked the switch and no light, my pen tells me there is electricity up to the light however, tried a few bulbs and checked all my neutrals are connected which they are.
Any ideas?
Should note that the constant live cable that i spliced onto, the neutral was not connected to the old switch or the switch wire at the switch. It was capped with a push fitting on its own/ as was the switch wire. (See attached pic)
Cheers,
Dan
Any ideas?
Cheers,
Dan
