leicesterfan
Hello.
I'm in the UK, and have some questions/concerns about my kitchen set up. So the fuse box has 4 breakers/circuits for the kitchen (the lighting is on a different circuit).
One circuit covers the electric oven, gas hob ignition and a plinth heater.
I then have a single 20A rated circuit, and two 16A rated circuits feeding various sockets above the worktops. I've worked out which circuits are linked to which plug sockets by flicking off the breakers in turn.
On the 20A circuit I have the fridge freezer, washing machine and toaster
On the 16A circuit I have the dishwasher and microwave
On the other 16A circuit I have the kettle and coffee machine (my wife has just bought an air fryer too, and the best place would be next to the double socket where the kettle/coffee machine live).
Now of course not all of these are running at the same time, but I'm getting paranoid that if I've got the dishwasher going, I can't use the microwave and vice-versa. If I've got the washing machine going, I can't use the toaster and vice-versa, and if I've got the kettle going, I can't use the coffee machine and vice versa. If I then put the air fryer on and needed the kettle, I'd have to unplug it and use a socket on another circuit (where nothing else is running!?)
Am I being overly cautious and thinking about things too much? Surely unless you're in a new build, you're not going to have umpteen dedicated circuits for the various appliances. Surely lots of people have a kettle and toaster on the same double socket and have both on at the same time?
