ice cube relay help wiring and will it work | on ElectriciansForums
Discuss ice cube relay help wiring and will it work in the UK Electrical Forum area at ElectriciansForums.net
DJ80D6
sacramento
super new to these things. i made a drawing to see if this will work. if so which ice cube relay should i use.
the picture shown is a hoa switch. when in auto position the wires coming out have 24vdc. the irrigation controller when command is sent it comes out as 24vac. can i have the switch make the 2 wires from hoa touch and make contact to turn on a pump basically.
[ElectriciansForums.net] ice cube relay help wiring and will it work
If the HOA switch outputs 24V DC, and the irrigation controller needs a contact-closure in a 24V AC circuit to operate, then any normal 24V DC relay will work. I.e. the relay must have a 24V DC coil, as AC and DC coils are different. The fact that it is switching an AC circuit to the irrigation controller instead of a DC circuit doesn't matter, as its contacts will be equally suitable for both.
I don't know what the output of the HOA switch is intended to drive, but if it is only a low-current output of a fraction of an amp, it might be worth getting a relay with a built-in back-EMF protection diode or adding one yourself, to ensure that the output is not damaged by the back-EMF from the relay coil when it switches off. If the output is intended to drive motors, pumps etc then it won't be a problem.
Also, I don't know what the control input to the irrigation controller consists of. If it is just a logic / control circuit that operates the solenoid valves / pumps by its own internal relays, then there will be very little current and the contact rating of your relay won't be important. But if for any reason that input is switching motors etc directly, then you would need to make sure your relay contacts have adquate current rating.
This might be easier to advise if you post the model numbers of the equipment.
Reply to ice cube relay help wiring and will it work in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
I guess the easiest way would be to run a supply from ignition /aux via a relay that drops the supply when the lights are on.
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
