Dodgy trade pictures for your amusement! - 1 Million Views! | Page 274 | on ElectriciansForums
Darkwood
West Yorkshire
Had an identical one on my 180A oil filled arc welder for about 30 years, plugged into a MK surface socket from the same era. Never showed the slightest sign of heat damage.
The one with a bolt replacing the fuse?
Bolts are made of steel, so that would have been a right bodge.
13A fuse with a bit of 30A fusewire soldered across it is much more sophisticated
Use the neutral pin out of another one, jobs a good un.
A bit off topic, but you really can't get the staff these days can you....
Photoshopped fake?
If the lid was to be placed 180 degrees, the pattern of the small bricks still doesn’t work.
There is no straight line of blocks up that edge like there is on the bottom
Photoshopped fake?
I'll trust your superior lego skills! I'm really struggling to tell with the camera angle.
Zooming in there are a couple of spots where 'grot' spans the edge and the cover but that could also be fake.
I saw it on a facebook group.
Kitchen RCD tripping problem. Besides various other problems like inaccessible sockets behind fitted units, some jerk has boxed in the CU....couldn't get the cover off.
.....and drilled through a ring final cable whilst boxing in pipework under the boiler.
Looks like it’s a Cornish farmers work which I see on an almost daily basis
