I want to install smart light switch into the wall socket that currently has a normal light switch. The smart switch requires a neutral wire which is not available in the current light switch wall socket.
There’s another light switch not far from this wall socket which does have a neutral wire.
Can I use the live/switched live wire from the current wall socket to connect the L and L1 of the smart switch, and the neutral wire from the other switch to connect the N of the smart switch that I want to install?
Thanks for your help.
