I need advice regarding an electronic problem on my Hayward Power-flo Matrix pool pump.
I notice that :
1. Neutral wire from source has become hot and cracked
2. Burn spots are present on the electronic board:
I marked on the photos my observations in red.
During the last days of operation, it took a little time to start from the switch. However, the pump was working fine. Neither the GFCI outlet nor the house breaker turned off the pump.
I need help to direct my investigations and fix it.
Where to start the diagnosis?
I notice that :
- Under resistance R1
- On the motor connection
- On neutral wire connection
