Hello and thank you for your time.
In the picture, the 6/3 gauge NMD wire is running though the basement ceiling and out of the house into the backyard. Its about 13 in off the ground and about 20 in away from the water line. I have some extra wire slack temporary taped up and covered with a bag.
My question is, when the GFCI box goes over it, can it go overtop at that location (13in off the ground), or will the wire have to elbow joint upwards and run into the GFCI box at some specific height and then of course another line run down again into the ground to the hotub?
I've seen similar wiring set-ups for AC wiring outside the house: wire exits at the same location 13in above ground, then redirect upwards in an cable cover, then into the box and then out again. See image
K
K
