DIY - Trailer AC Continuously Running | on ElectriciansForums
Discuss DIY - Trailer AC Continuously Running in the UK Electrical Forum area at ElectriciansForums.net
Indiana
First time DIY post here….
My wife and I bought an old, run down 70’s lake trailer and ran into an AC wiring issue.
Our thermostat is wired with white wire to W2, Red to RC, and jumper from RC to RH. There are two wires hanging by the furnace (old gas furnace that is out of commission due to the HOA park not having gas). When you cap these 2 wires, AC runs perfectly but will run until the wires are disconnected. I am assuming these 2 wires need to be ran to the thermostat so it can open/close the loop but no idea where they would possibly go.
DIYer here that is too cheap to hire a profession if it’s something I can do myself. I have an engineering degree so I’m not that stupid and can usually figure stuff out but electrical is one area that I’m not familiar with.
Any help would be GREATLY appreciated!
Call in an AC refrigeration tech to check the AC unit refrigeration side of things loss of refrigerant can throw you in the wrong direction when fault finding
'RC' and 'RH' are the inputs to the stat for cooling and heating, which in a home system might be fed by separate transformers. Here, they are presumably jumpered together as the same DC feed operates both functions. Then, the output you want for the A/C is 'Y', which becomes live from RC when cooling is needed. If there is no wiring attached to 'Y' or 'Y2' the the 'stat isn't wired to control the A/C. 'W2' is the output for second stage heating, so not relevant to the A/C.
Can you post some pics?
As of right now, this is the o
This is the only picture I have as of right now. The other 2 wires hanging that are capped are red/white. Those colors didn’t pop up when researching AC wiring.
[ElectriciansForums.net] DIY - Trailer AC Continuously Running
Reply to DIY - Trailer AC Continuously Running in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
Thank you so much. If I think of the stator/rectifier/regulator as one pulsating DC source and I ignore the AC aspect it makes it easier in my...
Since you have no grounds you need to put them circuits on GFCI breakers for your added protection. Adding extra receptacles is not going to be...
UPDATE: I finished this tonight and I'll be a monkey's uncle if there wasn't a metal box there and one of the NM cables (that looks like...
P
I done some searching the net trying to find a manual for the "bullmer 775 bandsaw". No luck so far. I have found out the blade is 405 cm long...
petke
P
