Lights and sockets on one circuit? | on ElectriciansForums
Discuss Lights and sockets on one circuit? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
London
Hi guys.
I had an inspection yesterday, where the lighting and sockets are in one circuit for each floor.
There are 3A fused spurs for the lights. I also need to replace the consumer unit with 18th edition one.
How would you code that? Any advice on the consumer unit would be appreciated.
Thanks[ElectriciansForums.net] Lights and sockets on one circuit?
Lights that are off a 3A FCU are perfectly safe.
You might code it C3 due to the lights failing if the sockets are tripped out (division of circuits 314.1).
That is an old looking CU but @westward10 is the best person to ask!
Good question I initially thought Square D QOE but they are missing the indicator window and the rating is painted on the toggle, so not Square D.
Not a common brand that immediately hits me but could be Mitsubishi. The ON/OFFS look hand painted.
OP any info on the front off the open flap.
Those are type 4, if they are flat around the toggle without the ridges then type 3🙃
Another thing, if they have some sort of addition to the terminal like a flat spring affair that is to increase their breaking capacity.
Reply to Lights and sockets on one circuit? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It’s difficult to advise on an electrical issue when some isn’t very conversant with electrical terminology.
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
