LonelyLuck
Hi All,
I have just installed 8x GU10 downlights in our kitchen with a 2 way setup using the 2 cable method, when I turned the light on they are running dim. I also found that if I turn another light on in the house they then go to full brightness and remain that way even if the other light is turned off and until they are turned off themselves, turning them back on they go dim again.
I'm going to rewire the 2 way 2 cable setup with 3-core and earth in hopes this fixes the issue, along with shortening some lengths of cable between the downlights.
Any suggestions on what might be causing this, am i on the right track?
