Anyone know what this cable is called | on ElectriciansForums
Discuss Anyone know what this cable is called in the UK Electrical Forum area at ElectriciansForums.net
Northamptonshire
Does anyone know what the cable in the picture is called? Or anything about it?
Labelling on the outside is “E SPC Electric Cable 600/1000v”
Its an odd one, looks like SWA. When you look inside it only has one core used for the live conductor. Then it has a load of black insulated strands that have been used for the neutral and 3 thicker uninsulated copper cores used for the cpc.
  • [ElectriciansForums.net] Anyone know what this cable is called
Normally used by power companies to come from street to cut out in property.
If it’s been used as a distribution circuit, must have been a spare bit lying around….
Or the bit in the pic has lost its cut out and floating around live and dangerous. ⚡⚡
The only time that is used is if you have a friendly meter man, he will gladly give you a few spare meters of it after he has just hooked up an iffy connection for you or moved a meter no questions asked.
Normally
I would say occasionally used by power companies to come from street to cut out in property. They tend to use concentric cable, with a combined neutral and earth surrounding the central live.
Reply to Anyone know what this cable is called in the UK Electrical Forum area at ElectriciansForums.net
Sounds more positive.
Went into an MCCB, terminated very nicely thank you very much, however it was just me doing some training with crimping. 'introducing extra point...
