Induction/gas hob install | on ElectriciansForums
Discuss Induction/gas hob install in the UK Electrical Forum area at ElectriciansForums.net
Auckland
We have an install where the client has supplied an induction/gas hob combination unit. We have a 6mm cable supplying the hob, the induction part is 7kw max draw which is hard wired. The gas side comes with a 3 pin plug hard wired so it will need a socket. We wouldn't be able to have these on the same circuit because it is effectively a 10A socket on a 32A MCB. Can anyone see any issues having 2 supplies to 1 unit?
If that was a valid reason then these wouldn't be allowed:
[ElectriciansForums.net] Induction/gas hob install
I have in the past fitted one of these underneath as well in this situation and simply left them both turned on.
Another approach which is more elegant is to use a dual cooker connection unit. If you want no arguments from any future electrician then run 6mm to a single socket. The current draw from the gas hob ignition will be miniscule and the fuse in the plug will protect it.
I could construct an argument why < 6mm would meet the regs but sometimes it's simpler to make it obviously comply.
spur off the 6mm feed to the hob. FCU with a 5A fuse. then to a socket for the gas ignition, ssimples.
The OP is in New Zealand
Reply to Induction/gas hob install in the UK Electrical Forum area at ElectriciansForums.net
In all likelehood, no different. The RCD on the left is looking for electricity that is going missing in action. If the total missing reached...
Recommended Sponsor News
Hi everyone,
