Wiring an MCB beetwen RCD and Main switch | on ElectriciansForums
Discuss Wiring an MCB beetwen RCD and Main switch in the UK Electrical Forum area at ElectriciansForums.net
Apprentice
Good evening,
I wondered how the MCB between RCD and the Main switch is wired while watching this video. Photo attached.
I assume a busbar link is connected to the main switch and mcb. Do the line conductors and the busbar connected at the same terminal and then go to the RCDSs?
Link to the video:
Cheers
  • [ElectriciansForums.net] Wiring an MCB beetwen RCD and Main switch
Reply to Wiring an MCB beetwen RCD and Main switch in the UK Electrical Forum area at ElectriciansForums.net
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
What is the distance from the point outside the house to the shed?
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Good point, they do look a bit 6mm-ish when you mention it, and that is not going to last long enough for a D63 to trip! It might, on a good day...
