Bolted neutral at BNO | on ElectriciansForums
Discuss Bolted neutral at BNO in the UK Electrical Forum area at ElectriciansForums.net
wokingham berkshire
Good afternoon all,
I have been asked to look at a problem with a bolted neutral but no one seems to know what exactly is the problem.
SSE metering want to install new smart meters at a block of flats but have flagged that as it is a bolted neutral bar. SSE have said that this cannot be carried out until it has been rectified. I have spoken to metering but I an now in a long technical route trying to locate an engineer who knows what is actually needed.
There are no fused switched isolators from the main fuses so I'm guessing that this is the main problem as the neutral cannot be safely isolated. Could really do with a new Ryefield chamber as well.
There are no hot spots noted but there are some neutral cables doubled up.
There are seven flats at this site with another 6 blocks with around 6/7 flats in each. all wired the same way!
Any ideas welcome.
[ElectriciansForums.net] Bolted neutral at BNO
Reply to Bolted neutral at BNO in the UK Electrical Forum area at ElectriciansForums.net
Responsibility is with whoever made final connections at the shower. The person that tested the supply at the shower has likely got those readings...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
There needs to be a DP means of isolation- if there are other isolators that can be locked that would be OK in my opinion.
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
