What speaker cable do I need to connect up these speakers? | on ElectriciansForums
Discuss What speaker cable do I need to connect up these speakers? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have just removed a rather expensive CD system from a house. I did explain to the customer that I thought it was worth quite a bit, but they just wanted shot of it.
Unfortunately no working speaker cables as I had to chop them off.
The unit is the bang Olufsen 9000, 6 CD player
[ElectriciansForums.net] What speaker cable do I need to connect up these speakers?
The speakers are Bang Olufsen beolab 4000 speakers. I believe one of them is mark1 and the other 2 speakers are mark2. They both have the 8pin round connectors in them for the speakers.
Do I just buy 8 pin Bang olufsen speaker cable? There seems to be 2 different types but they look identical.
First one = Powerlink mk 2 compatible - Black (8 pin DIN cable with fully wired 8 cores) - https://soundsheavenly.com/powerlink-8-pin-din-connection/23-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html
Second one = Powerlink mk 3 compatible (8 pin DIN) cable with 4 cores wired, low profile cable - https://soundsheavenly.com/powerlink-8-pin-din-connection/20-266-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/1-length-05m
Will either of the above 2 cables work?
Easy one !! The speakers are Active so yeas you will need 8pin cables . Dont go down a Rabbit hole on quality etc etc .We are NOT talking high end hifi at all .Not bad Hifi ... but not worth spending a fortune on cables
Thanks Luke.
There seems to be 2 types of 8 pin. See both my links. I'm not too sure if one is correct and one isn't, or if they both would be fine.
May I suggest that whatever cable you buy, avoid the uni-directional copper ones!
Also, you probably don't need to use this for your internal fuse
if you've cut the cables... can you count the cores?
I see the links show "fully 8 cores wired" or "4 cores wired",,,, so whatever cable is was??
That's a good idea!
But... I've now taken them out from where they were and there were 2 different types there as well!
1 x 8 pin went into a multi player port.
1 x 8 pin went in the CD player.
2 x 8 pins went into the speakers.
I've counted the cores.
In 2 of the cables there were 3 cores and in the other 2 there were 6 cores??
Its possible they both work .. as the main 4 cores will be cover signal and power .The 4 core might be for older (Like this ) models. I would just call them and ask .
Reply to What speaker cable do I need to connect up these speakers? in the UK Electrical Forum area at ElectriciansForums.net
If the ka rating of the MCB was to low it could happen or if it keeps getting reset over and over and over, it will fail.
My garage has had only one electrical outlet, I've decided to add 2 more with each feeding off the original outlet. But upon looking at the...
What an excellent post and series of answers. I'm replacing an old ceramic job with an almost identical Bosch induction hob to that of the...
44K
see me.:p
4K
