3 phase heater & Economy 7 wiring diagram question | on ElectriciansForums
Discuss 3 phase heater & Economy 7 wiring diagram question in the UK Electrical Forum area at ElectriciansForums.net
UK
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at night and 1 for the fan (this is live 24 hrs a day). The charging supply only comes live at night due to a dedicated timer installed on that circuit for the heater.
In the same office, we have a dedicated Economy 7 fuse box. This fuse box comes live when the timer from the electricity supplier turns it on at night. I have about 6 smaller storage heaters connected to this Economy 7 fuse box.
I would like to alter the wiring slightly to switch the 3 phase heater to use the Economy 7 fuse box to charge the heater at night like the other heaters (Fuse box is 3 phase). This would remove the dedicated timer and rely on the timer from the supplier to turn on the nightly supply as it does for the other heaters. The fan supply could then remain on the main fuse box to allow 24 hour power for it.
The reason I would like these changes is that it gives me more accurate sub metering for billing purposes and also means that the storage heater can never be charged on a peak time tariff accidentally.
The wiring diagram is attached as a photo. Can this be done? An Electrician had a look and said it can't be, it needs a dedicated timer and contactor and both supplies need to be on main fuse box and can't be split. Would like a second opinion though as I have hopes someone on this board can explain how it can be done!
  • [ElectriciansForums.net] 3 phase heater & Economy 7 wiring diagram question
Reply to 3 phase heater & Economy 7 wiring diagram question in the UK Electrical Forum area at ElectriciansForums.net
He can apply for an E7 tariff with or without storage heaters. It depends on his electricity usage profile on whether this is a good idea or not...
If you supply the heaters via the 24hr supply then you're relying on setting the off peak charging times within the heater itself. You will need...
Interesting what you say, I have allowed with my system for the change to be half hour out, so start charging at 0:30 and stop at 7:30 but night...
Thought this was sounding a bit familiar. A thread on the same subject from 2021,, There's a link to the manual, but no diagrams, in my post #2...
6K
