Socket outlet in a toilet? | Page 3 | on ElectriciansForums
Discuss Socket outlet in a toilet? in the UK Electrical Forum area at ElectriciansForums.net
O
omega
Hi all, just wondered if there is any specific guidance in the regs with relation to socket outlets in toilets?
Just in the process of doing a full rewire and the client has requested a socket in an outside toilet, ( new one on me and god knows what they want it for but hey, who am i to pry! ) No bath or shower, just the toilet. Any advice much appreciated guys and gals.
This is an eight year old thread you have dragged up, but the short answer is that there are no electrical regulations whatsoever pertaining to an outside toilet, whether or not it has a hand basin in it, other than the general regulation referring to equipment being suitable for the environment it's installed in.
I searched for info on this. Just received new Japanese toilet needing installing in a bathroom. Comes with a 120cm lead with prcd tester close to 13amp plug with instructions to test before use each time. What’s the rules on having a socket in the bathroom furthest position from bath and sink on wall to airing cupboard? Thanks for any advice.
Hi Brian. The prcd is close to plug and has to be checked before the toilet is used every time. See picture. I might be able to get the plug through plasterboard into a socket the other side but it will be very tight going. Will contact Washloo and ask them if they have a lead with a longer lead to the plug end.
  • [ElectriciansForums.net] Socket outlet in a toilet?
Poor design that. Makes it tricky to use other options, such as wiring to an FCU.
Well I did think of fitting a waterproof socket against the wall which would be safe but not sure that would comply with the standard.
It would be safe, as would an ordinary IP20 rated socket, if sensibly situated and outside the bath and shower zones, BUT there's nothing to stop anyone unplugging the loo and plugging in a hairdryer to use in the shower.
Any competent electrician conducting an EICR on this property would code the socket C2, giving the result "unsatisfactory" for the whole installation.
Its a WC not a bathroom (See Op's original Post #1)
I guess so. But there always a way for anyone to get an extension lead through to the bathroom plug in a hairdryer to use in the shower. But I see what mean. Is there anything against removing the plug and extending by soldering and shrink wrapping with a cable that’s connected through a wall elsewhere?
No, but I would actually use a proper ip rated connector, in addition, don't cut the cable as it goes into the plug's strain relief, actually cut it within the plug itself - this could add several mm to the available length.
Does the plug have an earth/cpc connection?
If it is just the line and neutral (I.e. a plastic earth connection) then you could just fit a 2 pin shaver style connector and install a shaver outlet for this device (assuming it's a low power thing)
It looks like a really well made plug which is annoying to think I might have to cut it off. See photos. Just also found out that the supply to the immersion comes off the ring main to the new section of the house so need another supply so floorboards up. Toilet takes 1.3kw.
See photos
Is it just the photo or is the earth pin sleeved with just the tip exposed? If it is and whatever it is thats connected isn't double insulated then cut it off and throw it away. You'll get no earth continuity. Come to think of it I can's see a BS mark on it.
Good observation. Apart from the BS1363 clearly marked! (Though the mark may not be genuine in any case)
I wondered that, but I think it might just be because the earth pin is in shadow.
OP, can you confirm?
1.3kW for a toilet?
What the heck does it do?
Heated seat, or macerater type waste?
It’s the latest Japanese toilet from company called Washloo. It washes and dries at temperatures you can set them at. Also has heated seat. They are great for people who have physical disabilities, dementia and suchlike. Helps to keep them from getting UTIs etc. Having said that people I know have visited Japan have them in great regard. This one’s made in China🙄
Reply to Socket outlet in a toilet? in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
Yep, rewired - all RCDs. Nice one mate, cheers, that sounds like a plan then.
Some of the points should have been picked up by previous people doing the testing. Sounds like this is a thorough report. Not everything is...
I'm sure others would pay handsomely for that!
5K
