Dodgy trade pictures for your amusement! - 1 Million Views! | Page 307 | on ElectriciansForums
Darkwood
West Yorkshire
Great selection of equipment for outside lighting underneath street lighting bollards. An ant nest colonised this one causing earth fault. SWA glands weren't even on properly and only BW type... All of the bollards were like this.
Client "the outside lighting hasn't worked for years and nobody can find out why"
Earlier this year, solar PV fire... Tripped out the main ryefield fuses back at the origin of supply. Looked into it, solar ac supply was just wired directly into the tails by the meter. Lucky the 90min fire protection of the riser worked!
The client was shouting asking for the building to be re-energised and I refused until further investigation. Took a while to find this mess and came back next day to fault find fully. If anyone had put fuses back in, the solar PV would be straight back into fault.
  • [ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views!
Saw some similar junctions recently. Why worry about fireproof enclosures or connectors, when you can use plastic and not need to worry about screwing on a lid.
Conductors don't appear as though they were ever pushed into that box.
That looks like fp200 fire alarm monkey cable.
12, maybe 24v. Untidy, but dangerous?
At least they used IP rated glands
Wagos are great but I've heard many people say "they are enclosed so don't need an enclosure". But its better than connector blocks wrapped in tape that used to be the norm before I guess!
Still plenty of it about, earlier this week found this:
Connector blocks wrapped in tape was always the best way for someone to bodge up a job so they could finish early on a Friday (or any other day)
people that don’t care about the quality of their work and are only interested in the payment will always cut corners like that. Wago‘s have just made it a bit easier for that type of person to just “make it work“ so they can go home early
