Just need some guidance | on ElectriciansForums
Discuss Just need some guidance in the UK Electrical Forum area at ElectriciansForums.net
Birmingham
Hey Everyone
Just need some advice and what to look out for. I've installed some rocker switches 24vdc for a project and they keep blowing after a period of time. Any chance you can point us in the right direction and what to look out for?
Thank you
  • [ElectriciansForums.net] Just need some guidance
When you say the switches “blow”, what’s happening? Do the just stop working? Stick open or closed? Actually “blow” with an audible sound?
As asked above, what is the load?
It might say it’s less than the 10A rating, but there are certain things that might have a larger start up current. Motors for example.
The load is c16 (Mains), a bit high but that's all we could we find and then we fused the transformer 2amps. The lights are for a light up board to notify people that they are in the building. Me and my work colleague have had a disagreement, he thinks it's the rocket switches and we need led lights but I think it's pulling too much current, that's resulting them to blow.
What are your thoughts?
Thanks guys
Thanks guys
The c16 is the breaker rating, not the load. What is the rating of the lamps you are switching with the rocker switches?
It appears to be a 24v PSU, so either way they are exceeding the contact rating, it's just a case of by how much :)
Indeed. I think an upgrade of the switches is definitely in order!
Although the rear of the switch in the photograph appears to say 10A 125V / 2A 250V.
Reply to Just need some guidance in the UK Electrical Forum area at ElectriciansForums.net
W
Pan connector to soil, not sure what needed Hi all, Need to change this pan con and am not sure what I'm looking at where the pan con and the...
WaterTight
W
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
My older card has it but my newer card doesn’t
I
Cleaning a Magnetic Filter without an isolation valve Hello All, We have a Vaillant boiler, it has an advanced protection kit fitted that gives...
i3_happy
I
K
How much adhesive needs removing between tiles & covering a chip Hi, Looking for advice mainly on how much adhesive I should remove from between...
kitkat
K
