Discuss Led panel dimmer and switch wiring. in the Lighting Forum area at ElectriciansForums.net
I have a led panel that i want to dim. It is dimmable but without a dimmable driver.
I have a dimmer module and a dimmer switch as shown in the foto.
Can anyone sketch me a diagram on how to wire the bits together.
Thanks.
Reply to Led panel dimmer and switch wiring. in the Lighting Forum area at ElectriciansForums.net
Find this LED dimming issue very frustrating. Had to replace back the old halogens because the Dimpull bathroom switch failed to support LEDs...
try a varilight pro dimmer for led's
Hi :)
I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
Hi all
I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
